I am attaching the process below on how to remove this. You noted this is a 4 cylinder and the spark plugs are accessed through the valve cover, so you just need to pull the four plug wires that are coming from the coil.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Below you will see what the engine looks like to help identify the coil and plug wires. Once you pull the plug wires you will just need to remove the plugs and the guide above will help with this.
Please run through all this info and let us know what questions you have.
Thanks
Feb 6, 2022 at 8:26 AM
