2003 Dodge Stratus Passenger window regulator replacement i
ROBERTDWHITE
Interior problem
2003 Dodge Stratus 6 cyl Two Wheel Drive 35000 miles
I need step by step removal and replacement instructions for the passenger side replacement of the window regulator. The motor appears to be working. The vehicle is a two door model.
Thanks
Sep 25, 2010 at 8:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
biggest part is removing door panel, if you checked motor i'm assuming door panel is already off?
once panel is off you have to disconnect glass from its track and prop it in up position. disconnect the wiring and then just unbolt regulator.
Sep 26, 2010 at 11:42 AM
