2003 Dodge Stratus engine not working
105,020 MILES • 6 CYL • 2WD • AUTOMATIC
RAMIREZ23
I would like to know if the engine has gone bad on my car. I was driving it down the street when it just turned off on it's own and it hasn't started since. the only warning i had was the oil light and it started overheating a little. How long did I run it after this started happening might be a question that I would be asked and it was about 5- 10 minutes. the oil level on the car is good, because i just had an oil change, and i don't see any water in the oil dip stick.
please let me know what you can suggest I do?
Thanks,
Juan Ramirez
San Antonio,Tx
Apr 11, 2009 at 10:37 AM
ZACKMAN
  • 4,202 POSTS
I would first check your timing belt. If TB is in good condition, check the fuel pressure at the fuel rail (about 45 psi) for fuel pump operation.
Apr 13, 2009 at 3:33 PM
