2003 Dodge Stratus Coolant Bottle is leaking
2003 DODGE STRATUS
140,009 MILES • 4 CYL • 4WD • AUTOMATIC
MAHASIN
On May 23, 2008 I took my car to my mechanic to have a Cam Sensor Circuit replaced and although my car had never ran hot before I took it to him he replaced my thermostat. As of May 31, 2008 my car ran hot, I filled the coolant bottle with antifreeze not realizing there was a leak, the next morning the bottle was empty. I filled it again today and drove 3 miles it ran hot again. I pulled over immediately because I kept watching the needle on the temp gauge, the bottle was empty again. Why is it doing this?
Jun 2, 2008 at 5:31 PM
BLACKOP555
  • 10,386 POSTS
when you fill it up can you verify if it is indeed coming from the coolant resevoir/bottle and not somewhere else?
could be due to a loose hose, bad radiator cap, even a bad hose on it, most likely it is a crack, its been known to happen!
Jun 3, 2008 at 1:10 AM
