2003 Dodge Stratus code p0344
78,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGJIM1215
car has code 344 and wont rev over 2500 rpm in any gear what to do
Aug 3, 2009 at 11:23 AM
  • 31,937 POSTS
Hi there,
This is a cam position sensor, check the continuity of th wiring to the ECU, and if ok, replace the sensor.
mark (mhpautos)
Aug 3, 2009 at 6:54 PM
BIGJIM1215
I have replaced the cam and crank sensor. tested all the wires, checked the timing marks, and it still kicks the light on and wont rev over 2500 rpm while driving down the road
Aug 11, 2009 at 3:22 AM
  • 31,937 POSTS
If the sensors are ok, the wiring checks out valve timing is ok, i would be getting the ECU tested for a fault, this is unusual but if you are sure that everything else is ok, you may have to look here next. The question is still open so if anyone else has come across this you may get some more information, also make sure that the sensor plugs are in good condition as i have had other cars do similar things with suspect sensor plugs causing problems.
Mark
Aug 11, 2009 at 10:28 AM
