2002 Dodge Stratus Water pump repalcement
115,000 MILES • 4 CYL • FWD • AUTOMATIC
JFAVSPOON
My water pump is leaking, so im replacing it. Im kinda lost on what needs to come off though. I have the front right motor mount removed as well as the front part of the dust cover. Does the back dust cover have to come off? Also it looks like im going to have to remove the timing belt and gears. I plan on replacing the belt any way. But DO i HAVE to remove the gears? thanks
Jul 1, 2008 at 4:23 PM
KGDECKER
  • 10 POSTS
[quote:5ecab44516="jfavspoon"]Engine Cooling problem
2002 Dodge Stratus 4 cyl Front Wheel Drive Automatic 115000 miles
My water pump is leaking, so im replacing it. Im kinda lost on what needs to come off though. I have the front right motor mount removed as well as the front part of the dust cover. Does the back dust cover have to come off? Also it looks like im going to have to remove the timing belt and gears. I plan on replacing the belt any way. But DO i HAVE to remove the gears? thanks[/quote:5ecab44516]
Jul 1, 2008 at 4:51 PM
