2002 Dodge Stratus water leaking inside
98,000 MILES • 6 CYL • FWD • AUTOMATIC
DONALD GRAHAM
i have water leaking on driver side front and rear floor board. its not coming from outside because it doesnt happen when it rains or you wash it. i dont think its coming from engine because its not losing any water. it only seems to happen when the car is running. could this be a a/c condensation problem and if so how do i fix it. it seems the longer i drive the more water gets on the floor
Sep 26, 2010 at 2:06 AM
  • 110,251 POSTS
Have you checked under the dash to see if you can identify any leaks? Usually, the AC will leak on the passanger side. However, stranger things have happened. Have you checked the AC drain to see if it is plugged?
Sep 26, 2010 at 3:43 PM
