2002 Dodge Stratus something wrong with my car heater
98,738 MILES • 4 CYL • FWD • AUTOMATIC
TIMPERR1
I have a 2002 Dodge Stratus. The heater only works on #4 not on 1,2, or 3, if i cross the terminals on the back of the switch they all work, by doing that it burns the switch out. I bought a new switch but still the same problem. it worked fine till last yr. the blower motor works fine, i tested it. What else could it be. all the wiring is good also.
Feb 4, 2009 at 9:45 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:e09fbbf269="timperr1"]Heater problem
2002 Dodge Stratus 4 cyl Front Wheel Drive Automatic 98738 miles
I have a 2002 Dodge Stratus. The heater only works on #4 not on 1,2, or 3, if i cross the terminals on the back of the switch they all work, by doing that it burns the switch out. I bought a new switch but still the same problem. it worked fine till last yr. the blower motor works fine, i tested it. What else could it be. all the wiring is good also.[/quote:e09fbbf269]
It is your Blower Motor Resistor. It is locate in the duct work under the passenger dash.
Feb 4, 2009 at 10:03 AM
