2002 Dodge Stratus power windows
92,000 MILES • 6 CYL • FWD • AUTOMATIC
SJCALES
rear drivers side window will go down but not up! checked connector at motor have 12 volts on both prongs, swaped switch from pass. side and still nothing, replaced motor with new one and still same problem, replaced front switch on drivers door with one from junk yard still the same thing, with motor out of door motor turns one way but not the other, I was thinking maybe motor was in a bind, with motor unhooked from cable window moves freely,
please please help!!!!
Feb 7, 2010 at 4:56 AM
CARADIODOC
  • 34,408 POSTS
First, check for broken or frayed wires in the rubber tube between the left front door hinges. This used to be a very simple circuit, but now a complicated, unreliable Body Computer is involved. There's no easy way to test it except by trying a different one.
caradiodoc
Feb 9, 2010 at 7:57 PM
