2002 Dodge Stratus Passenger door lock not working
109,000 MILES • 6 CYL • FWD • MANUAL
DAVIDLCALDWELL1973
This is a 2002 2dr. stratus R/T coupe.
The electric door lock appears to release the passenger door, but when you select the door lever to open the door from the inside the door does not open. However, you can still open the passenger door from the outside.
Jun 8, 2010 at 4:36 AM
  • 110,248 POSTS
remove the door panel and check the linkage to the lock. It sounds like it broke or came loose.
Jul 8, 2010 at 12:52 PM
FELIXM
Not sure, maybe door has Child safety lock that was activated
Aug 6, 2010 at 2:04 AM
  • 110,248 POSTS
That is very possible. Open the door from the outside. You should see a lever to select child safety if it is equiped.
Aug 6, 2010 at 5:07 PM
