2002 Dodge Stratus OIL
111,279 MILES • 4 CYL • FWD • AUTOMATIC
ARLICIA
I was changing my spark plugs the other day and two out of four of my spark plugs that i pulled out had oil all over them i know that cant be good just wondering maybe what the paoblem could be so i could fix it or at least try to lol thank you for your time.
Apr 6, 2010 at 5:11 AM
XSHAWN117X
  • 12 POSTS
Probable cause can be worn piston rings or too much cylinder clearance which will let extra oil reach the upper chamber. Although a worn valve cover gasket is the more probable cause. It's inexpensive and easy to fix.
Jun 2, 2010 at 10:34 PM
