2002 Dodge Stratus Noise While turning both directions
75,000 MILES • 6 CYL • FWD • AUTOMATIC
SCAPPEL0125
Dodge stratus has a grinding/rubbing type sound while turning either direction. not sure where to start? CV joint, bearing? How much would it be to have a shop service this issue?
Jun 22, 2010 at 11:44 AM
  • 110,248 POSTS
Without knowing the problem, I can't supply an estimate. Have you checked brakes? Also, when you turn, do you hear a clicking sound (CV Joint) or a grinding (Brakes or Wheel Bearing)? Please note, that usually when a wheel bearing goes bad, the sound will come and go when making turns?
Jul 8, 2010 at 12:12 PM
