2002 Dodge Stratus Noise While turning both directions
2002 DODGE STRATUS
75,000 MILES • 6 CYL • FWD • AUTOMATIC
SCAPPEL0125
Dodge stratus has a grinding/rubbing type sound while turning either direction. not sure where to start? CV joint, bearing? How much would it be to have a shop service this issue?
Jun 22, 2010 at 6:44 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Without knowing the problem, I can't supply an estimate. Have you checked brakes? Also, when you turn, do you hear a clicking sound (CV Joint) or a grinding (Brakes or Wheel Bearing)? Please note, that usually when a wheel bearing goes bad, the sound will come and go when making turns?
Jul 8, 2010 at 7:12 PM
