2001 Dodge Stratus speedometer, transmission
PATRICK FEIST
Transmission problem
2001 Dodge Stratus 4 cyl Two Wheel Drive Automatic
The speedometer quite working, and the transmission will not shift out of low gear. Should I replace the input and output speed sensor on the transmission?
Jun 21, 2010 at 4:10 AM
  • 110,248 POSTS
That is where I would start. However, usually a bad speed sensor will kick the check engine light. Has that happened?
Jul 8, 2010 at 12:18 PM
