2001 Dodge Stratus MANFACTURE IGNITION CONTROL MISFIRE
2001 DODGE STRATUS
145,000 MILES • 4 CYL • FWD • AUTOMATIC
TERRY MELTON
CHANGED MOTOR the motor taken out had broken timming belt an was thought to have jumped time bought anther 2.4 HERD IT RUNNING GHREAT put it in the car that was removed from an when trying to start back firing like it has jumped time took plug out to see if they were all firing and the # 1 & 4 plug firing white hot plug 2 & 3 firing light yellow cold to start with then stoped firing altogether changed coles an same thing whats wrong is it the computer
Feb 8, 2009 at 2:46 PM
  • 110,244 POSTS
Hi:
Did you replace the coil with a new one? The computer tells the coil to fire, but has nothing to do with the quality. Are the plugs / wires new?
Mar 13, 2009 at 3:44 AM
