2001 Dodge Stratus Crank shaft sensor
141,000 MILES • 4 CYL • 2WD • AUTOMATIC
CONNIE PENNER
We just replaced the crank shaft sensor in my 2001 dodge stratus coup, however it wont start. Hooked the computer back up to it and it still sends the same code. is there another part that needs to be replaced? Are there 2 sensors? We also replace the cam sensor. Is there a shut off breaker? and if so where is is located?
Aug 19, 2008 at 3:30 AM
BMRFIXIT
  • 19,053 POSTS
can u let me know what is the code
do u have spark
did u check fuel pressure
check fuses and ASD relay
Aug 19, 2008 at 8:54 AM
