2001 Dodge Stratus Cooling Fans
84,012 MILES • 6 CYL • FWD • AUTOMATIC
LG3248
My fans do not come at times.
I have changed out the Thermostat, temp. senser,
fan relay, last year the fans were replaced.
Some days the fans work fine, all the time as they should.
I noticed today, I started the engine and turned on the A/C and the fans do not come on.
Aug 19, 2009 at 10:24 AM
LEGITIMATE007
  • 5,121 POSTS
you will need to check the a/c fan relay,mostlikely its become weak or no good all together
thanx
Aug 19, 2009 at 1:34 PM
LG3248
I had already changed the fan relay(part#MR400709),
what I noticed is that the fans only come on at the high speed for the A/C, not at lower speeds.
Right now I am testing the car while it is cold, using just the A/C.
Aug 20, 2009 at 4:43 AM
LEGITIMATE007
  • 5,121 POSTS
the radiator fan relay and the a/c fan relay are two different relays, does the radiator fan come on when the car gets too warm. ok the one you replaced is the a/c relay
Aug 20, 2009 at 4:56 AM
LG3248
This past month, while driving the gauge goes to Hot, so that tells me the fans do not come on when hot, some days no problem. When this happens I have to turn on the heater on hot setting and the temp comes down.
did I mention that I have a 3.0 6 cyl. 2001 dodge stratus?
If the 2 fans come on right now with the A/C on high, is the fan relay OK?
Thanks
Aug 20, 2009 at 5:11 AM
LEGITIMATE007
  • 5,121 POSTS
the fans will come on whether its on low med or hi, the engine . if the fan do not come on when the a/c is turned on can be the hi pressure switch, one fan is for the radiator, and one fan is for the a/c, totally seperate
Aug 20, 2009 at 1:37 PM
