Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Stratus
Climate Control
Blower Fan
Speed
2001 Dodge Stratus Blower only runs on high
2001 DODGE STRATUS
124,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVERSTREAKER
MEMBER
the blower fan only runs on high. I've tried to find a relay but am unable. Could there be a resistor?
Oct 24, 2008 at 12:35 PM
BLACKOP555
Experienced Mechanic
yes that is the sign of a bad blower motor resistor. the relay would deal with the blower not working on high but on all the other speeds.
resistor is used to limit the voltage giving the lower speeds.
Oct 24, 2008 at 4:06 PM
SILVERSTREAKER
MEMBER
Thank you for the info, but I am having trouble finding the resistor. Do you know where it is located?
Oct 26, 2008 at 10:19 AM
BLACKOP555
no problem.
one last thing i need ot know if its a
stratus ES
stratus SE
or stratus R/T
Oct 26, 2008 at 11:05 AM
SILVERSTREAKER
MEMBER
Stratus SE.
p.s. Thanks
Oct 27, 2008 at 1:07 PM
BLACKOP555
no problem am here to help.
it is located on the right side of the HVAC housing. diagram isnt loading. but thats where it is
Oct 28, 2008 at 12:51 PM
BLACKOP555
wow, great write up, tell you friend thanks!
and thank you for posting that.
Oct 30, 2008 at 12:34 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
