This vechile battery will not hold a charge. Battery has been replace. Alt replace. Show little amp draw when checking. When I unhook negative cable it will hold a charge. Install a battery disconnect on postive cable. After couple of days of sitting with disconnect in use the battery will lose it charge. Tried different battery with same result. Any ideas? Thank you
Dec 3, 2009 at 7:58 PM
