2001 Dodge Stratus Airbag Light
2001 DODGE STRATUS
103,500 MILES • 4 CYL • FWD • AUTOMATIC
SCOREBOARD2009
Three days ago, I was driving home. I was driving about 65-75 miles an hour. My air bag light came on and stayed on while I was driving. When I arrived home the light was still on. Since that time, my air bag light stays on in the car. There is no other problem with the car that I have notice. About four weeks ago or less I had my front passenger side automatic lock switch changed. The motor went out. I have no idea if it has anything to do with what is happening now with the car. What do I need to do to figure out and fix the airbag light so it will not come on and stay on while I am driving.
thank you
Jan 17, 2009 at 3:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
The SRS (Supplemental Restraint System) or air bag system is a vital safety feature in your vehicle. If the air bag light is illuminating for longer than one minute, you need to have a diagnostic scan done. A professional repair shop will use the Diagnostic Readout Box (DRB) test to access the SRS on-board diagnostics of your vehicle and pinpoint the issue. This will ensure your vehicle is repaired correctly and in a timely manner without "throwing parts" at it, so to speak. Please see your local dealer or reputable repair shop to have your SRS issue solved as soon as possible.
Thanks for using 2CarPros.com!
Jan 17, 2009 at 11:00 AM
