2001 Dodge Stratus
DEXTERFLOREY
Drive Train Axles Bearings problem
2001 Dodge Stratus Front Wheel Drive Automatic 197000 miles
when i am riding down the road the front wheels feel like they are rubbing, when the brakes are applied it isn't as rough. i took off the wheel and it didn't seem like it was the brakes, there was no grooves on the rotors or no signs of rubbing or nothin. i was thinkin it could just need new bearings but im no mechanic, any ideas?
Aug 23, 2010 at 9:00 AM
  • 110,248 POSTS
Check the passanger side to make sure the tire isn't hitting the belt shroud. Also, are the brake pads good? Finally, does the noise change when making turns?
Aug 23, 2010 at 4:35 PM
DEXTERFLOREY
yea the brake pads are good i still have about a half inch of pads left. i think that i found out what it was when i put the car up on jack stands i took the wheels off, as well as the whole brake assembly. i grabbed on to the wheel spindle on the driver side and it seemed to be fine, the bearings did not feel ruff at all. then i went to the pass. side and grabbed the spindle and i had to much play in it. it would wiggle up and down. so i started to spin it and i could feel the bearings grinding as it spun around. does that sound right? thanks
Aug 25, 2010 at 9:54 AM
  • 110,248 POSTS
That sounds like the problem. Let me know if it takes care of it for you.
Aug 25, 2010 at 2:00 PM
DEXTERFLOREY
ok thanks for the help guy
Aug 27, 2010 at 5:59 PM
  • 110,248 POSTS
Let me know what you find.
joe
Aug 28, 2010 at 3:49 PM
