2001 Dodge Stratus
KASICZKA6
2001 Dodge Stratus
Hi I was wondering what does the TCL and Anti Lock colntol lights means because sometimes it's on the the other times it just turns off by itself
Thank You
Apr 6, 2009 at 7:34 AM
CARADIODOC
  • 34,414 POSTS
TCL is traction control. This is an add-on option when you have anti-lock brakes. If the ABS doesn't work, the traction control won't either.
Noticing that the lights turn off while driving is a valuable clue in finding the problem. When the yellow ABS light is on, the system is disabled and you will just have normal brakes. A diagnostic fault code will be memorized in the ABS computer. Your mechanic will connect a hand-held computer called a scanner to retrieve that code. The code doesn't tell him the component that failed; it tells him the circuit or system that has the defect. He will still have to troubleshoot the system.
caradiodoc
Apr 7, 2009 at 5:39 AM
