2000 Dodge Stratus water pump
BUDDAH123
Engine Mechanical problem
2000 Dodge Stratus 4 cyl Two Wheel Drive Automatic
I NEED INFORMATION ON CHANGING THE WATER PUMP ON MY DODGE STRATUS.
Jul 23, 2008 at 1:30 PM
BMRFIXIT
  • 19,053 POSTS
1.Raise vehicle on hoist. Remove right inner splash shield. Remove accessory drive belts and power steering pump. Drain cooling system. Support engine from bottom, and remove right engine mount.
2.Remove power steering pump bracket bolts, and set pump and bracket assembly aside. Note that lines need not be disconnected.
3.Remove right engine mount bracket. Remove timing belt. Remove inner timing belt cover. Remove water pump-to-engine attaching screws. Remove water pump.
Jul 23, 2008 at 2:00 PM
