2000 Dodge Stratus Turn signals
2000 DODGE STRATUS
106,000 MILES • 6 CYL • FWD • AUTOMATIC
NATEDGR82002
My blinkers work sometimes and not at others. Think I need a new fuse or replace the flashers. If it's the flashers, where are they located and is it easy to replace? How would I go about replacing them?
Nov 11, 2008 at 2:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It is located on top of the steering column under the cover. You have to take the dashboard cover off starting at the sides and down the front and take off the steering column cover. It plugs in from the back so all you do is unplug it.
You might want to check your wires leading into the fusebox in the car before going through the process of disassembling your dash cover.
It sounds like a faulty or loose wire to me.
Nov 11, 2008 at 2:49 PM
