2000 Dodge Stratus signal lights
LJACKSON0406
  • 8 POSTS
Electrical problem
2000 Dodge Stratus 4 cyl Two Wheel Drive Automatic
hello i have a problem with my signal lites they are not stay on on when i make a turn. when i make a right or left turn they would only blink once and then shut off where could this problem be coming from and how would i fix it?
Oct 8, 2010 at 6:28 AM
JDL
  • 16,098 POSTS
There may be an issue with the multifunction switch. I'd have to check the feed to and from the switch when the problem is ongoing, to be sure. My info shows the combo turn/hazzard flasher is part of the multifunction switch?
Oct 8, 2010 at 8:12 AM
LJACKSON0406
  • 8 POSTS
ok thx now where is that multifunction switch located on the the car?
Oct 8, 2010 at 10:57 AM
JDL
  • 16,098 POSTS
In the steering column. Your turn signal arm is part of it. Be aware of the air-bag.
Oct 8, 2010 at 11:32 AM
