2000 Dodge Stratus rear window defrost
TCDEBACA
Electrical problem
2000 Dodge Stratus 4 cyl Front Wheel Drive Automatic
My rear window defrost stopped working I changed the fuse relay but it still dosen't work. It stopped all at once no sign of trouble
Jan 12, 2009 at 3:01 AM
ZACKMAN
  • 4,202 POSTS
So, did you replace the fuse or the relay. The circuit has one of each.
https://images.2carpros.com/forum/automotive_pictures/55316_99stratusdefogger_1.jpg
Jan 13, 2009 at 6:14 PM
TCDEBACA
I just checked the fuse I thought you had something but the fuse is fine
Jan 14, 2009 at 2:00 AM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_00stratdefog_2.jpg
OK. Let's start this one more time. Look at the wiring diagram again. The circuit has a total of 3 fuses and one relay. I need you to check ALL fuses and relay. Under the hood, inside the power distribution box. 1. Check fuse #12, 40 Amp fuse. On the left side of driver dash, inside the junction box. Open the driver door to gain access. 2. Fuse #6, 10 amps. 3. Fuse #15, 10 amps. 4. Rear window defogger relay. There are a few relays inside that junction box, just swap a couple of them around. Then re-test.
Jan 14, 2009 at 11:28 AM
