2000 Dodge Stratus no spark to 3&4 cylinder
91,763 MILES • 4 CYL • FWD • AUTOMATIC
CFK3366
well first of all the water pump went out so we desided to change water pump and timing belt spark plugs/wires the car sat down for about a year before i got it but from what the last owner told me tht thy changed all those iteam so i did the check and everything seems to be in order but now im having problems with firing in 3&4 cylinder have no spark 1&2 is firing ok but looks like the 1&2 will soon follow 3&4cause by looking at the plugs its not like its really burning like it should it had a browndish look and the top of the elctrode not tht clean ash look like the plugs are firing do i hve re do the timing again i checked the timeing marks and seem to be fineand would it be why its not firing in 3&4 help would be nice Aloha
Sep 30, 2009 at 8:20 PM
BMRFIXIT
  • 19,053 POSTS
Suspect bad coil
also do a compression test
Oct 1, 2009 at 11:29 AM
