I purchased a car from an auction that has been sitting for at least 2 years. It will not start on its own without the aid of starting fluid.
If I feed it starting fluid for 15 � 20 seconds it runs smoothly on its own and continues to run without a problem. Turn it off and try and start it again, it refuses to run on its own without feeding it starting fluid once again. You can hear the fuel pump run for a couple of seconds when you turn the ignition to the �on� position.
I replaced the fuel filter AND the fuel pump and it was of no help. Any ideas? Thanks.
Aug 8, 2010 at 9:51 AM
