2000 Dodge Stratus electrical problem
LJACKSON0406
  • 8 POSTS
Electrical problem
2000 Dodge Stratus 4 cyl Two Wheel Drive Automatic
hello
my car break lights wont come on when i break to stop what could that mean? i already replace the bulb and they turn on at nite but not when i break. Also when i turn on my signal lites to make a turn they quickly shut off and wont stay on why is that?
Oct 6, 2010 at 4:30 AM
WRENCHTECH
  • 20,760 POSTS
Is the 3rd (high mount) brake light working?
Oct 6, 2010 at 4:34 AM
LJACKSON0406
  • 8 POSTS
yes everything thats elecrtric on the car is working fine. but when i step on the breaks the lite dosnt come on.
Oct 7, 2010 at 11:51 AM
WRENCHTECH
  • 20,760 POSTS
Did you read what I asked you?
Oct 7, 2010 at 12:26 PM
LJACKSON0406
  • 8 POSTS
im sorry but no the 3rd (high mount) is not working at all.
Oct 8, 2010 at 4:00 AM
WRENCHTECH
  • 20,760 POSTS
Then you need to go to the brake light switch under the dash at the brake pedal and test for power coming in all the time and going back out when the brake is applied.
Oct 8, 2010 at 4:02 AM
LJACKSON0406
  • 8 POSTS
ok thx i will try it and let you know how it gose.
Oct 8, 2010 at 6:24 AM
LJACKSON0406
  • 8 POSTS
ok wat is that peices called behind the break pad and how do i check it? do i need special tools or anything?
Oct 8, 2010 at 8:03 AM
WRENCHTECH
  • 20,760 POSTS
You use a 12v test light to test for power. You may have to get someone to do it for you.
Oct 8, 2010 at 8:05 AM
