2000 Dodge Stratus don't shift from first
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JERAZ88
My dodge stratus's timing belt went out and i got it replaced now my speedometer don't work and also the car won't shift out of first the car sat for almost a year and now it starts and runs but don't shift gears. I checked the tranny fluid and that is fine and i'm not sure why the speedometer and the tranny don't switch from first. I have park, reverse, and only the first gear in drive on an automatic transmission
Sep 16, 2010 at 8:31 AM
MADMIKE1735
  • 951 POSTS
sounds like a bad speed sensor.... i recommend replacing both.... the pair should run around 80$ in parts, and an hr of your time replacing.... they are located on the driverside of the transmission, usually easier to acess from under the car.
Sep 24, 2010 at 3:00 PM
