2000 Dodge Stratus cooling Fan
97,000 MILES • 4 CYL • FWD • AUTOMATIC
TLCOLE
just replaced blower motor resister worked ok about 4 times on 1,2,3,4, now only 3,4, are working Please
help could it just bad resister
Sep 18, 2009 at 11:49 PM
  • 110,248 POSTS
It could be a bad resister. However, the motor may be drawing too many amps and causing the resister to burn up. If I had to guess, I would say the motor is the problem. You could try another resister since they are cheap, but it if happens again, replace both the resister and the motor.
Oct 8, 2009 at 4:21 AM
