2000 Dodge Stratus asd/pcm
122,000 MILES • 6 CYL • FWD • AUTOMATIC
JJ1823
I HAVE AN INTERMITTENT START CAR STARTS AND RUNS FINE WHEN IT WARMS UP(NOT OVERHEATING)IT DIES AND WONT START GOES INTO NO SPARK...... WHEN COOLS DOWN STARTS RIGHT UP AGAIN BUT DIES EVERYTIME.....CURIOUS ABOUT ASD FUSE RELAY I JUMPED IT TO NO AVAIL.... IS IT NY PCM?????
Jan 19, 2010 at 8:50 AM
BMRFIXIT
  • 19,053 POSTS
Check and suspect crank sensor at 1st
Jan 19, 2010 at 10:20 PM
TWINKEY1
  • 49 POSTS
had a similier problem with my 2003 dodge Stratus it has 68,754 miles,it was the coill pack
Apr 3, 2010 at 5:29 PM
WRKOKART
check the wire going to the crank sensor open the insulation or heat shield you may find wires that shorted due to heat from exhaust
Feb 13, 2012 at 3:56 PM
