2000 Dodge Stratus
ELISHAB
Engine Cooling problem
2000 Dodge Stratus 6 cyl Front Wheel Drive Automatic
car is leaking antifreeze with out it being on. replaced a heater hose now it leaking by the water pump while the car is off
Jul 27, 2010 at 12:53 PM
  • 110,251 POSTS
Under the water pump is a weep hole. If the seal or bearing is bad in the pump, coolant will leak from there. Check that and let me know what you find.
Aug 6, 2010 at 5:24 PM
