2000 Dodge Stratus
100,000 MILES • 6 CYL • FWD • MANUAL
JDODGE
heater blower only works on hi speed.thinking it is a bad switch or relay.what could it be.
Oct 22, 2009 at 9:17 AM
JDL
  • 16,098 POSTS
Might be resistor block. High speed doesn't use resistor.
Oct 23, 2009 at 2:28 AM
DARWING
I replaced two resister blocks over a period of a couple of months because the problem would reappear.
Finally I changed the blower motor assembly which permanently fixed the problem. Believe me, with 100K miles, they run a lot, get old and begin drawing excessive amperage which takes out the resistor block.
Do yourself a favor and save the frustration - change the blower motor at the same time. Your already there when changing the resistor block and the whole job should take even a novice under 2 hours.
Oct 23, 2009 at 3:32 AM
