2000 ac heater blower relay
149,000 MILES • 4 CYL • FWD • AUTOMATIC
KEVINSCAMAROS
where is the location of the blower relay?The blower works on high speed only .I checked the switch its ok. there is no power to the resistor on low and medium speeds,I suspect the blower relay.
Aug 17, 2008 at 8:11 AM
OBXAUTOMEDIC
  • 3,715 POSTS
[quote:a86453999d="kevinscamaros"]Air Conditioning problem
2000 4 cyl Front Wheel Drive Automatic 149000 miles
where is the location of the blower relay?The blower works on high speed only .I checked the switch its ok. there is no power to the resistor on low and medium speeds,I suspect the blower relay.[/quote:a86453999d]
It sounds more like your Blower Motor Resistor which is locate in the duct work under the passenger dash.
Aug 17, 2008 at 8:35 AM
