1999 Dodge Stratus wont run
1999 DODGE STRATUS
192,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUEOVALMAN
car runs good when cold but after awhile dies. i can recycle the key a few times and it will start but keeps dying. not much fuel pressure at bleeder on fuel rail
Sep 26, 2009 at 8:04 AM
  • 110,244 POSTS
It sounds like a fuel pressure problem. I need you to check it when this happens.
Here is a "how to". Check it and let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Note: You'll need a gauge to check it. Many parts stores will lend or rent the gauge.
Oct 7, 2009 at 2:34 AM
BLUEOVALMAN
thanks for the response. i thought the same thing about the fuel. i put on a new fuel pump and still had the same problem. i then talked to chrysler guru and he recomended a new crank position sensor. changed it and she runs like a top again thank you.
Oct 7, 2009 at 6:49 AM
  • 110,244 POSTS
I'm glad you found the problem. I'm surpised the check engine light didn't come on. Usually, a crank sensor will set it.
Regardless, let us know if you have questions in the future.
Oct 7, 2009 at 1:07 PM
