1999 Dodge Stratus Battery
1999 DODGE STRATUS
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
MROWE34
How do I change the Battery? I can't find it? The fuse box and vent are blocking everything.....
Oct 31, 2008 at 4:08 AM
ZACKMAN
  • 4,202 POSTS
Jack up the front driver side. Turn your wheel all the way to the left. (you will have more room if you remove the wheel, but it is not necessary). Remove all screws and plastic rivets holding the wheel well splash shield. Remove the shield. You will see the battery. You will need 10mm socket to remove the battery holder. The same socket will remove the battery terminal connector.
Oct 31, 2008 at 5:25 PM
MROWE34
Strange place to put the battery it fired right up!
Oct 31, 2008 at 6:08 PM
