1999 Dodge Stratus
184,000 MILES • 4 CYL • FWD • AUTOMATIC
RABBITRUN107
My car makes a noise like it's going over grated road but when I turn one way, it's gone. I turn the other way, it's still there. Of course the noise is more so the faster I go and less when I am coming to a stop. Is it the bearing? And if so, is it costly to fix or dangerous to drive on?
Aug 8, 2009 at 2:33 PM
OBXAUTOMEDIC
  • 3,717 POSTS
Is it more of a clicking sound? from what you describe it sounds like it could be a CV Axle going bad.
A bearing usually sounds like a low roar or scraping and is usually constant, except that it may sound higher or lower depending on speed.
Aug 8, 2009 at 2:42 PM
RABBITRUN107
no, it's definitely a low roaring which gets louder as the car goes faster. it's very annoying after awhile
Aug 8, 2009 at 4:04 PM
OBXAUTOMEDIC
  • 3,717 POSTS
Ok, then most likely it is the bearing. Also have you had new tires put on? I know on some vehicles new tires will make a roaring sound for a few weeks after install.
Aug 9, 2009 at 1:20 PM
RABBITRUN107
well the tires look new and still have nipples on them but I've been driving this with the noise since I got the car back in May so I'm assuming that would have been worn off by now. I thank you for all your help, I just wish I had a mechanic in the family to do this without taking all my money.
Aug 9, 2009 at 1:47 PM
OBXAUTOMEDIC
  • 3,717 POSTS
Yes, I would say the tires should have worn down by now also.
Also, do you feel a vibration in the front floor board on either side? If so that would also point to the bearing.
Aug 9, 2009 at 1:54 PM
RABBITRUN107
not that I have noticed. How much would it cost to have that repaired?
Aug 9, 2009 at 2:46 PM
OBXAUTOMEDIC
  • 3,717 POSTS
Your vehicle has what is called Hub Bearing Assemblies and if I am not mistaken your is Bolt on, and the cost of the bearing if you can do it would cost about $100. If have to have a garage do it you will be looking at about $500 - $800 or so for total job.
Aug 10, 2009 at 2:31 PM
