1999 Dodge Stratus
1999 DODGE STRATUS
JOSH1975
Transmission problem
1999 Dodge Stratus 6 cyl Front Wheel Drive Automatic
I REPLACED A TRANY IN A DODGE STRATUS WITH ONE OUTOF A SEABRING I PUT STRATUS SENCERS IN THE TRANY DO I NEED TO USE SEABRING SENCERS OR DOES IT MATTER AND IS THERE A TRANY COMPUTER AND WHERE IS IT LOCATED
WHEN I FIRST PUT THE TRANY IN I ONLY REPLACED ONE OF THE SENSERS AND WHEN TEST DRIVING IT SHIFTED DOWN REALY HARD WHEN YOU CAME TO A STOP SO I REPLECED THE OTHER ONE NOW THE TRANY WON'T SHIFT OUT OF FIRST AND ALL THE DASH LIGHTS COME ON
Mar 12, 2010 at 9:17 AM
SERVICE WRITER
  • 9,123 POSTS
First make sure that this transmission is definitly compatible. Sebring had more than one option I believe.
IF it is, then the TCM ( transmission control Module) needs to have a re-learn procedure performed. This must be done with a scanner that is capable of doing this. Certain criteria must be met before the procedure is done. This is all done through the DLC.
Mar 12, 2010 at 9:28 PM
