1998 Dodge Stratus tune up
USIX7
1998 Dodge Stratus 4 cyl Front Wheel Drive 100000 miles
I installed new bosch spark plugs and new wires.
the car is still rough idlleing
Aug 15, 2008 at 2:34 AM
BLACKOP555
  • 10,386 POSTS
first thign i would do is pull the IAC module, clean it up good and reattach, clean throttle body/plate out and then let it run. any better now? you can try seafoam in a vaccum lin also that cleans her up good.
if that is not the solution then you should check for vaccum leaks, faulty pcv valve, sticking egr valve, or a bad IAC module.
Aug 15, 2008 at 5:10 AM
