Engine not running ?
257,000 MILES • 6 CYL • 2WD • AUTOMATIC
PONDER3
Went dead, found split crankshaft pos sensor,changed sensor and timing belt still no fire, no service engine soon light, rpm gauge goes to 2000 when key is turned on without cranking engine
Mar 15, 2009 at 11:53 PM
  • 75,988 POSTS
still no fire, Did you meant no spark or it cranks over and w/n start
Mar 16, 2009 at 12:12 AM
PONDER3
engine turns burn no spark, i can hear fuel pump pressurize it just spins
Mar 16, 2009 at 12:42 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 16, 2009 at 1:32 AM
