1998 Dodge Stratus Headlight Replacement
GALILEO9
Electrical problem
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic
How do I replace the lights in the car?
Apr 10, 2009 at 11:25 AM
CARADIODOC
  • 34,413 POSTS
Open the hood, unplug the connector, twist the lock ring and remove it, pull the bulb out, push the new bulb in, push the ring on and turn it, plug in the connector, close the hood.
Don't touch the glass of the new bulb. Fingerprint grease will burn into it from the heat and cause early bulb failure.
caradiodoc
Apr 10, 2009 at 11:59 AM
