1998 DODGE STRATUS ES POWER STEERING PORBLEMS
AIRFORCESAM
Just had some questions, seem to be having a problem with steering, the wheel gets really tight but only when running at very low speeds and in reverse, as soon as you give it gas the wheel just loosens up easily, also when the wheel gets tight you hear a little bit of squeaking. I woud be greatfull to find out if ne1 knows exactly what it is! thanx.
Jan 5, 2006 at 9:33 AM
PURPLEMOONIE
I had a similar problem with my 98 stratus. I turns out that the steering fluid needed to be changed/flushed. The problem went away and hasn't been back since!
Feb 7, 2006 at 7:50 AM
