1998 Dodge Stratus code po303
92,000 MILES • 4 CYL • 2WD • AUTOMATIC
LWE
misfire cylinder #3
first thank you for the info on replacing the fuel injector.
the plug wire, plug, coil, and fuel injector for cylinder 3 have all been replaced as well as the tps. the misfire still exists and the code reapeared. what is left? the car runs perfect some times and other times it stumbles? any help would be appreciated.
Jan 5, 2008 at 7:58 AM
BLACKOP555
  • 10,386 POSTS
Whats the compression on that cylinder? Change your coil pack for that cylinder
Jan 5, 2008 at 11:27 AM
