1998 Dodge Stratus Car wont star
LIL_JP2
  • 1998 DODGE STRATUS
1998 Dodge Stratus 6 cyl Front Wheel Drive Automatic
I have a 1998 dodge startus and I have replaced the fuel pump, sensors, and got a tune up and still dont know why it wont start. I need some help figuring out whats wrong with my car.
Wednesday, October 20th, 2010 AT 3:27 PM
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Wednesday, October 20th, 2010 AT 3:31 PM
