1998 Dodge Stratus Brakes
93,500 MILES • 4 CYL • FWD • AUTOMATIC
JAZADA3
I have replaced my front and back brakes several times in the last 6 months. usually about every month or two. I have no idea what else to do and why they keep going out.
Oct 28, 2010 at 5:47 AM
MADMIKE1735
  • 951 POSTS
1998, i believe you have drums in the rear and rotor in the front... can you elaborate a bit more on your problem??? also, do you know offhand if you have ABS
Oct 29, 2010 at 4:09 PM
JAZADA3
You are correct, i do hve drums in the rear and rotors in the front and i do have ABS. I have had them changed several times and they last a month or two at the most. Sometimes my fluid will leak out and sometimes it wont. i have changed the master cylinder twice in the last 4 months. it is always the right side that goes on the front and back.
Oct 31, 2010 at 11:31 PM
