1998 Dodge Stratus battery
109 MILES • 4 CYL • FWD • AUTOMATIC
JIMDEL
just got car it needs a battery were is it i just see were you jump not the battery under the hood
Dec 15, 2007 at 11:32 AM
  • 31,937 POSTS
Hi there,
I found this on the web,
i hope it helps
It's battery is in the left front fender in front of the wheel. Access to the battery is achieved by removing a plastic panel in the wheel well. It is just barely possible to remove the battery if the front wheel is turned all the way left. However, it's a little easier if the front wheel is on an block that elevates it about 1.5 to 2.0 inches. This will allow the battery to clear the lower plastic fender/splash guard and permit it to slide out while it is on the ground. Else, you are stuck with the standard procedure which is to remove the front wheel.
There is a pair of heavy duty terminals under the hood.
Mark (mhpautos)
Dec 15, 2007 at 9:01 PM
