1998 Dodge Stratus
150,000 MILES • 6 CYL • FWD • AUTOMATIC
TERRYTERRY
MY CHECK ENGINE LIGHT COMES ON CHECK THE CODES IT SHOWS MISFIRE ON NO 5 CYL RESET THE COMPUTER RUNS GREAT FOR 50 OR 60 MILES LIGHT COMES BACK ON CHECK CODES SHOWS MISFIRE ON NO 1 AND 4 CYL NEVER THE SAME HAVE REPLACED PLUGS AND WIRES MAP SENSOR CRANK SENSOR AND DIST BUT STILL MISFIRES HAVE ANSWER THANKS
Feb 22, 2010 at 1:42 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 22, 2010 at 5:08 PM
