HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Stratus
Ignition
No Spark
1998 Dodge Stratus
RYE RICHMOND
MEMBER
1998 DODGE STRATUS
6 CYL
FWD
AUTOMATIC
129,484 MILES
HAVE NO FUEL, NO SPARK ANY IDEAS
Saturday, October 31st, 2009 AT 1:59 AM
JDL
MECHANIC
Welcome to the forum, check the cam and crank sensors. You can also check primary voltage to ignition module and injectors, engine cranking, dark green wire with orange tracer.
Sunday, November 1st, 2009 AT 1:00 PM
Please
login
or
register
to post a reply.
Related No Spark Content
No Spark. I Think It Has A Electronic Distributor?
I Am Working On A 98 Dodge Stratus 2.5v6 And There Is No Spark. I Think It Has A Electronic Distributor, I Had The Cap Off And Replaced The...
Asked by
j.stieg
1 IMAGE
1998
DODGE STRATUS
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
Car Stopped While On High Speed
The Car Stopped On The Road And Series Of Test Was Carried Out, First, No Spark On The Plug, Check The Ignition And Replaced With Another...
Asked by
mufteeh
1998
DODGE STRATUS
1998 Dodge Stratus 1998 Dodge Stratus Losing Spark
Please Help. Our 1998 Dodge Stratus Is Losing Spark. There Is No Consistent Time When It Does This; It Can Be While Idling For A While Or...
Asked by
thepoweroftwo
1998
DODGE STRATUS
1996 Dodge Stratus No Fire From The Ignition Coil
Electrical Problem 1996 Dodge Stratus 4 Cyl Front Wheel Drive I Have Replaced The Ignition Coil, Relay, And There Is Still No Fire...
Asked by
Jose Banda
1996
DODGE STRATUS
What Would Cause No Spark And No Power To The Fuel...
I Was Driving My Car To Work And It Died. It Started Back Up And Did Fine. When I Got To Work And Parked, And Turned The Car Off, I Tried...
Asked by
buddhaluv79
1 IMAGE
1995
DODGE STRATUS
VIEW MORE
Ignition No Spark
Ignition System Testing
Ignition Coil System Test Repair - All Cars
