1997 Dodge Stratus will not start
10,500 MILES • 6 CYL • FWD • AUTOMATIC
WELDERDA
the car will not start now it dos not have spark and we havea new brain box and that did not help when it did it would run until you put it in drive then it will dye when you restart it starts right back up but then it will dye again when you put it in drive
Nov 27, 2009 at 5:34 AM
JDL
  • 16,098 POSTS
Welcome to the forum, if your saying it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If that checks out, use a gage and check fuel pressure. Any codes?
Nov 27, 2009 at 6:55 AM
